i have a roof all at 35 degrees but i have this strange section, where the end of tiles is sitting lower, any ideas thanks?
If you didn't intentionally put in an edge offset, you probably had an Offset/Overhang defined and used Pick Wall Tool on that one wall and the Pick Lines Tool on the others.
...you can also use Align Eaves to fix.
