Hello all,
I have made a toposurface and I want to create the road. I have a crossroad each of them with a different slope.
I used the building pad tool but lengthwise of the road the slope changes constantly. So how I can 'match' the two roads ?
I don't know if my explanation is crear...
I would use subregions for roads on a topo surface. That or Site Designer.
What do you think about Graded region ?
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
If I use subregions they will follow the toposurface... The evel of the road is different
Hi
If you are working with levels and have those data, then you may use "Floors " and "Modify Sub Elements"and give elevations
the way they are designed...
you can have just one Floor to take care of multiple legs of the Road and all will fit in smoothly..
( you cannot give slope input in this case, Slopes will generate automatically according to the various heights of points..
you can introduce multiple points, lines, breaks.. check out "Modify Sub Elements " for more details..
Cheers !
