RL
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
1026 Aufrufe, 2 Antworten
RL
the spot elevation mark deosn't show the correct height. as you see in the elevation it is 166300 but it shows 16900. The floor slab is set at the correct level and it is not offseted. How can I get teh spot elevation correct? The file is also attached for further perusal. i have also checked the view range.
Its my irst time encounetring such a issue and I am not a begginner in revit. my file is too large to attach -57MB.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
I don't see where it says 166300.  Is your Spot Elevation relative to Project Base Point or Survey Point?
Nachricht 3 von 3
FGPerraudin
hi @Anonymous,
You wouldn't happen to be annotating your ceiling, view being orientated towards the top?
Measure wise it would make sense!
(ceiling plan OR view orientation sertting)?
François
Francois-Gabriel Perraudin
BIM management and coaching
