Ridges using fascia tool. How to clean up.
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
stuart
535 Aufrufe, 10 Antworten
Hi All,
I am using REVIT LT and while I am sure in place mass modelling could sort this in FULL revit.
I am wondering if anyone has managed to clean up the ridges when using the fascia tool? Is there another way to achieve my goal?
See the attached images.
Beschriftungen (3)
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: stuart
Does LT have Beams?
...are you using fascia tool for valley flashing. Kind of looks that way in your second screenshot. The fascia in the first screenshot should be easily corrected though.  That's done using Fascia tool; right?
Nachricht 3 von 11
stuart
als Antwort auf: barthbradley
It does have beams.
These are hipped roofs.
Normally it would clean up, but because there are two different angles at play 15 deg and 37.5 deg it's creating this ugly issue.
Nachricht 4 von 11
Can you share the file please?
Nachricht 5 von 11
stuart
Hi There,
Model attached.
Nachricht 6 von 11
Here's my solution:
In-Place Modeled Void cuts clone Roof Type.
Nachricht 7 von 11
For a cleaner, create another thin roof with the exact footprint (copy), then use vertical opening cut to cut to the ridge footprint.
Nachricht 8 von 11
als Antwort auf: ToanDN
That's pretty much what I did above.
Nachricht 9 von 11
stuart
Thanks for this.
Nachricht 10 von 11
stuart
Thanks for this way. I can do that with REVIT LT.
Nachricht 11 von 11
@stuart wrote:
Thanks for this.
Glad my solution worked for you.  Pretty nifty, huh?
