Ribbon View Problem
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
SerhanB
520 Aufrufe, 2 Antworten
Ribbon View Problem
Hi there,
I've just switched to 2021 version. I'm having an odd problem with ribbon. As you can see from below, button images are not rendered correctly when mouse is over. What is the issue here? any ideas?
Thanks!
Serhan BAKIR
http://www.stand.com.tr/
Tags (2)
2 ANTWORTEN 2
Nachricht 2 von 3
L.Maas
als Antwort auf: SerhanB
Never seen this before. Some things you can try:
-Switch off hardware acceleration in Revit Options
-Look for new graphics card driver.
-(Re)Install .Net framework
-Reinstall/Repair Revit
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 3
SerhanB
als Antwort auf: L.Maas
Thanks Louis,
hardware acceleration for visual experience is the problem, now I switched it off and ribbon behaves normal. I'll also update the graphics driver and see if it's the main issue..
Serhan BAKIR
