Rhino to Revit impossible hell, roads, flyovers the same problem, explode, fatal
3 ANTWORTEN 3
Nachricht 1 von 4
596 Aufrufe, 3 Antworten
First, I want to make roads in Revit (see picture 10). Well,, Revit just won't allow it.
Then I tried to make the lines in Rhino and import them in Rhino. Tracing is terrible not possible. Exploding the lines.., Revit will make them flat. I tried every possibility to export from Rhino to Revit. But, when I explode the mass or want to adjust the masses. Hell. Export as Autocad, Arcisat, Sketchup, everything. And still it is impossible to make roads in Revit which look the way I want to make the roads.
See all my attached pictures. Does somebody know how to export 3D lines from Rhino to Revit and use them? Or at least, well, I want to adjust the roads whenever I needed to. Or does somebody know how to make Roads in Revit? Flyovers.
Sorry for my language. I am in a hurry and working on this issue for more than two months. I post all the pictures beneath this.
Does somebody know the answer?
01 flyovers I want to make
02 road profiles I want to use
03 rhino test file with lines surfaces and masses
03 masses before the explosion
05 natural selection of revit only the masses survive
06 the 3D stuff and lines before the explosion
07 magical flat paper world after exporting
08 sketchup export
09 the mysterious disappearing of the lines and even the masses
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
[deleted message]
Nachricht 3 von 4
[deleted message]
Nachricht 4 von 4
[deleted message]
