My rhino model is a curvy pipe structure and when I exported it to revit there was multiple pipes that had a lot of unnecessary lines. I exported it as an ACIS (*.sat) file but it ended up with the same result.
I assumed you have already tried to link 3dm file directly in Revit and it didn't work?
It didn't work as the 3dm didn't import, or imported but the mesh lines are still visible?
I used "Import CAD" to import the rhino file. It works but it shows the dense meshes. I did try using "Link CAD", it took out the dense meshing but it imported in the wrong spot and did not cut for the section drawings.
Create a generic model in place and Link the 3DM in it.
