When the family type of revit is obtained by Grasshopper and placed at the point specified by Grasshopper, no object appears in the view of revit. However, the object of the specified family type is displayed in the view of rhino.
I will explain the components. First, select the face of revit's mass model in Graphical element. Next, divide the faces with Quad Panel and get the vertices of each face created by the division with Deconstruct brep. Next, get one vertex for each face. Finally, use Add Component(Location) to enter a family type named “panel” and place it.
Is there anything I should check?
Thank you in advance for your answer.
Resolved.
I changed the Revit project template file, created the masses in a new project file, and when I used Rhino inside Revit, they appeared correctly in the Revit view.
If anyone knows why the problem was solved, please let me know.
It looks to me like you are wanting to create a facade using pattern based curtain panels. This is how we do that in the Revit world (no Rhino gymnastics necessary):
