RFA to RVT (or STP/STEP file) conversion request
5 ANTWORTEN 5
Nachricht 1 von 6
maxim.teleguz
562 Aufrufe, 5 Antworten
Can someone covert this cad model please?
5 ANTWORTEN 5
Nachricht 2 von 6
robert2JCCH
als Antwort auf: maxim.teleguz
Not sure what the request here is.
What file format do you want this family file converted to? What's the application?
If you want this exported, won't you need to modify the louver dimensions to your application prior to doing so?
.RVT is a Revit project file. This is a single louver modelled for architectural use (it notably uses wall hosting and doesn't have duct connectors).
Nachricht 3 von 6
maxim.teleguz
als Antwort auf: robert2JCCH
the goal is to use it in inventor
Nachricht 4 von 6
maxim.teleguz
can you please get me a step file?
Why would you open it up and not export a step file? why tease me?
Nachricht 5 von 6
robert2JCCH
For starters it's a flexible family. What size would you even need?
You also can't directly export to STEP via Revit: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-do-I-convert-a...
STEP files would require an intermediary like dwg or fbx and one additional program.
You can open a project file in Inventor: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Opening-or-importi...
The parametric qualities are lost in conversion.
Nachricht 6 von 6
maxim.teleguz
can I get a "SAT" file or "DWG" or "STL" file then? I can export the 3D from the dwg then if needed.
