Revitte kendimiz bir merdiven tasarlamak isteyince resimde görüldüğü gibi uyarı veriyor nedeni nedir??? Yardımcı olursanız sevinirimm
I don't understand. That has nothing to do with Stair Path. But, in answer to your question: Stairs have a Base Level and Top Level, as well as Base Offset and Top Offset. Those parameters control the height, or Rise of the Run.
...with Stair by Sketch, which it sounds like you are using, you need to add more risers of course.
