Revit2016 印刷できない
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
keiko.nihei
229 Aufrufe, 1 Antwort
Revit2016 印刷できない
突然、印刷できなくなった。
下記、設定をクリックしても、反応がなく、印刷できない。
1 ANTWORT 1
Nachricht 2 von 2
nicholas_seibert
als Antwort auf: keiko.nihei
Hi, this is a known issue caused by a windows update, we have made some improvements to later versions of Revit to avoid this.  If you change your default printer to the XPS driver that is shipped with windows your print dialog should work properly.  Once you are in a functional print dialog you should be able to use any driver to print.  Most other printers won't have this issue either, so can try other PDF drivers too, but XPS will work.
Nicholas Seibert
Principal Revit QA
