Nachricht 1 von 6
453 Aufrufe, 5 Antworten
Revit
Is Revit 2016 compatible with Windows 10? I have tried to download it a number of times and each time, it fails.
5 ANTWORTEN 5
Nachricht 2 von 6
matthew.d
als Antwort auf: Anonymous
Hi @Anonymous,
Welcome to the community!
You can see all the compatibility for Windows 10 here. You can more specifically see all the system requirements for Revit here. I would recommend using Revit 2017 for Revit, if possible.
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
Nachricht 3 von 6
David_W_Koch
How are you trying to download it?  Are you using the Install Now option?  That method requires having a good internet connection during the entire installation process.  Try downloading the installation files in one or more ZIP files from the Autodesk Virtual Agent.  If there are multiple ZIP files, save them all to the same folder.  Once all are fully downloaded, double click on the "001" file to start the extraction process, making note of the location to which the files will be extracted.  All of the ZIP files will be extracted by the one action.  When the extraction is complete, go to the root folder to which the files were extracted and double click on the Setup.exe file to start the installation.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Nachricht 4 von 6
als Antwort auf: David_W_Koch
Yes, I am downloading it straight from the website.
I am not tech savvy so I am unsure how to extract files etc.
Nachricht 5 von 6
als Antwort auf: matthew.d
I tried downloading 2017 but encountered the same issue.
Nachricht 6 von 6
David_W_Koch
The files are self-extracting ZIP files.  If you can double-click on the first one (if there are more than one), you have all the tech skills you need.  Just make note of the folder (and path) to which they extract, then navigate to that folder and double click on Setup.exe to start the installation process.
David Koch
Blog | LinkedIn
