Revit Zoomwheel
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
433 Aufrufe, 3 Antworten
Revit Zoomwheel
How can I adjust the zoomwheel direction in Revit 2018?
Any suggestion would help. Thanks.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
You will need to use a 3rd party mouse macro program. I use a program called XMouse Button Control. That lets you set different functions for each of your mouses buttons on a per-program basis. It will let you reverse the scroll zoom direction in revit (but it will also reverse the scrolling direction in any lists or menus in revit too)
Nachricht 3 von 4
Thank you very much for your suggestion. I will try that.
Nachricht 4 von 4
Hi I tried Xmouse. You're right it is good but it also messes up other MMB functions. Maybe I will just put cad zoomwheel settings in AutoCAD in line with Revit zoomwheel settings
