I am new with worksharing.
When using Revit and using Worksharing, how do you access a dedicated server space for worksharing? How do two users in a group access the same central file?
Thank you
@Anonymous wrote:how do you access a dedicated server space for worksharing?
talk to your IT department. i would assume you have a folder structure on your network? but once a central model is made, don't move it if you can at all help it!
when you start making worksets, your file will become Workshare Enabled.
Howard Munsell
you can try to refer to these LINK and LINK and see if helps .thanks
