Revit workshared file is not stable.
3 ANTWORTEN 3
Nachricht 1 von 4
dream.du
256 Aufrufe, 3 Antworten
Hi, I worked on a worksharing Revit file recently. But I found it is not stable, especially compared with the non-worksharing file. For example, I changed the dimension or some detail lines, ect., and I saved the file afterwards. But the next day, when I saw the same drawing, it turned to be unchanged. And it also went wrong with the linked CAD file, the file cannot be shown properly. I searched for the answers, sometimes it worked, but some answers don't work out. But it didn't occur to me when I worked on the non-shared file. Besides, I worked on the Revit 2020. I don't know if the new version works better.
Beschriftungen (2)
3 ANTWORTEN 3
Nachricht 2 von 4
kimberly_fuhrman-jones
als Antwort auf: dream.du
Hi, @dream.du
Welcome to the forums! As this is not a request for a new feature or enhancement, I am going to move this thread to the forums where you will be able to get support for the issue you are having.
Thank you for your submission!
-Kimberly
Kimberly Fuhrman-Jones
Revit Community Manager
Nachricht 3 von 4
RDAOU
  • Where is it workshared, on the Local Server/Network or on the Cloud?
  • Where you working on a local copy or the central when the work was not updated?
  • Are the Local and the Central using the same version/build? Both need to be matching and preferably the latest
  • Did u use sync after the changes?
  • Do you have read and write permission to the folder where the central is saved?
Nachricht 4 von 4
ennujozlagam
try to install latest updates from autodesk and before closing the file you have to synchronize to central and see if helps. thanks
