Newly installed Revit 2024. I can open the program without any problems but when I try to open any file, whether it be a new or old one, it starts loading and the cursor keeps spinning but won't open.
Gelöst! Gehe zur Lösung
Gelöst von nad_nt. Gehe zur Lösung
Did you update the Revit 2024 to latest update 2024.1.1?
Yes, I just installed the newest version of Revit, because I was changing from 2023 to 2024.
The previous advice was ensuring you have all 2024 updates installed there have been a several since initial release so this is the most likely solution.
To help as 2023 & 2024 are different installations and have their own updates , you can check your version from Help > About (very old image used)
Revit latest updated Version 2024.1.1
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/1BlfQlbA9wWd1JmijceW6d.html
Solved it:
Navigate to C:\Program Files\Autodesk\Revit ####\AddIns\SteelConnections.
Rename Autodesk.SteelConnectionsDB.addin to Autodesk.SteelConnectionsDB.OLD
Rename Autodesk.SteelConnectionsUI.addin to Autodesk.SteelConnectionsUI.OLD
