I don’t have templates in my Revit 2020? I just installed the program but when trying to open a new project there are no templates only shows <None> as in the picture.
Gelöst! Gehe zur Lösung
Gelöst von aRcHiTeCt.JM. Gehe zur Lösung
… hi @Anonymous
… go to revit-2020-content
… follow the procedure … download them, install them
… and you will get all templates and families working
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Hi @Anonymous ,
You can download the templates like @aRcHiTeCt.JM mentioned.
Alternatively, DACH Region templates can be found here: https://www.rug-dach.de/download/templates.html
You will need to set the Path for the templates in your Options:
Cheers, K
Kunal Tuljaram Gaidhankar
Thanks, but these are not the templates that comes with the Revit installation , right?
These are templates for what? To replace the original Revit ones?
Nope. Some Revit User Groups made Templates that region specific. Like in Spanish or German.
Basically it addresses the specific planning process requirements for these regions.
