I can't change any window parts material in exported fbx model to Lumion, all of the windows appear as a whole component, even though I have different materials assigned to glass and frame in Revit window family. How can I fix that?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
There are default Revit materials with no assets, do I have to create custom ones?
You don't "create" Assets. You assign Appearance Assets from the Asset Browser to the Material . The Appearance Asset is what you see when you Render.
