Revit Wall Opening - Delete
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
samye228
681 Aufrufe, 3 Antworten
Issue is a shared wall was created, one side is the bedroom, the other is the great room. The wall appears to have a cutout and the properties say it is a structural rebar cover.
If I delete the cutout then I get an error concerning rooms, which I understand but why did the wall not heal itself? How can I remove the wall opening?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: samye228
Can you show the properties of that thing?
Nachricht 3 von 4
samye228
als Antwort auf: ToanDN
Nachricht 4 von 4
@samye228 wrote:
It appears to be a model in place wall.  If you want the opening then you can delete this model in place wall, or demolish it.  Then draw a room separation line at opening to separate the rooms.
