I am trying to resize a wall using a dimension.
I get the error : Can't change dimension to this value.
Is the wall locked in somehow?
Is it because I have played with the wall profile?
What could be causing this?
Moreover,could there be conflicts when adjusting a wall profile in elevation and then editing this wall in plan?
Finally, I find walls sometimes refuse to come together despite wall join adjustments and start sapping strangely. I may be missing something important. Any tips or resources that would go through these issues more fundamentally?
Reveal Hidden Constraints
...did you place dimensions inside Edit Profile sketch mode? If so, I don't think Reveal Hidden Elements will show those.
I don't think a hidden element is the issue. I currently redraw the wall and things seem to work.
Regarding your other issue your are having with automatic joining of walls; did you know that you can disallow joining on placement of wall. Look on your Options Bar when you place a Wall and you'll see a toggle for Allow-Disallow Join. Choosing Disallow Join will disable Auto-Join. Also, walls don't necessarily need Allow Join enabled to join. The Join Geometry Tool will get you the same visual effect.
