Revit wall footage
6 ANTWORTEN 6
Nachricht 1 von 7
267 Aufrufe, 6 Antworten
Revit wall footage
Hello
I have a project in revit. I want to material takeoff for wall but I don't want all the walls. how can I learn wall footage that half of a floor or multiple walls
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
It  sounds like you want to simply filter the schedule by some unique identifier.  Maybe a Mark or Comment given the walls?
Nachricht 3 von 7
als Antwort auf: barthbradley
building 3 tiers
in the first photo I made half of the 1st floor visible
calculates the 3 floor walls when I do material takeoff but I want to half of 1 floor
Or if I select 2 or more wall haw can I this wall area
Nachricht 4 von 7
Set up filter rules in the MTO Schedule itself to exclude or include the elements you want.
Nachricht 5 von 7
thank you for your interest
But I didnt do it. with filter, I can not solve it. as shown in the photo, I select some walls (blue walls) but wall properties wall area blank.
Nachricht 6 von 7
Because you are selecting multiple walls.  The properties does not show SUM values for multiple selected elements.
You need to add a value to the Comments field of those wall and use the field to filter the schedule as mentioned by @barthbradley
Nachricht 7 von 7
als Antwort auf: ToanDN
thank you I will try
