Revit vs. Architectural AutoCAD
kcarlson70
kcarlson70
Wasn't sure where to post this.  I'm a custom home/light commercial designer.  I created building plans and digital models using Architectural ACAD (3D version).  Lately, I have been contemplating switching to Revit and I am trying to figure out if it is worth it. I am so proficient in ACAD but I am noticing more and more firms are moving to Revit - especially in the engineering fields.
What are your thoughts?
Would Revit that more advantageous that Archiectural ACAD?  Has anyone worked on both and could explain the benefits of a switch?  The money part is insanely expensive - I am a one man show 😉
Thanks so much
KimCarlsonDesigns
L.Maas
Yeah. I moved from vanilla Autocad to Autocad Architectural to Revit.
When I started with Revit most of my clients and suppliers were still working with Autocad. However at that point export/import of autocad from/to revit was sufficient (for me) to collaborate on projects.
For me the main reason was my clients. I had/have to deal with people from many different backgrounds. This includes people not familiar with reading 2D layouts. So to be able to show them a 3D representation was a big plus.
A second big improvement for me personally was the parametric behaviour of Revit. In Autocad (Architectural) I had to deal with a lot of blocks. On regular basis I had to update many blocks because of changes. In Revit I was able to use families. In several cases I could replace 100 blocks with a single family. What used to be a lot of work in Autocad (Architectural) was done quickly in Revit.
And now I am more and more involved in projects were also the contractor/clients work in Revit. So slowly it is not an advantage anymore but is becoming a necessity.
You will have to find out how things are in your situation. Talk to your suppliers and your clients. Maybe in your case Autocad (Architectural) will do just fine.
Louis
Please mention Revit version, especially when uploading Revit files.
