Hello I don't see anything below the Second Floor in Plan view in Revit 2019.
Could you please refer to the attached file and tell me what could be the reason? Thank youuuuuu!
Gelöst! Gehe zur Lösung
Gelöst von bin. Gehe zur Lösung
Gelöst von Vasilii_Bogdan. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Could be Phasing. Set Phase Filter to "None" to verify.
Here's a cheat sheet to reference when you can't find "stuff" in a view:
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
Thanks so much for reply.
However, the person below got it right it was phase filter which needed to be set to "none"
Thanks so much! I was looking for answer to this problem for several days and you gave me short and right point that worked!
Good to hear, at least now you know it’s not View range issue. But you need to decide a proper phase filter for your view. None is more for trouble shooting.
https://revitpure.com/blog/6-tips-to-master-revit-phases
this can be helpful.
