Revit View Filters by Host View for Worksets
2 ANTWORTEN 2
Nachricht 1 von 3
1109 Aufrufe, 2 Antworten
View Filters in Visibility Graphics overrides based on a linked file’s Workset name appears to be disabled in Revit 2019. View Filters are unable to control visibility of a linked Revit model component (such as a wall) when view filters are set by Host View utilizing a Workset name. Please note that this issue exists only in Revit version 2019, since the customer has been using this method in previous versions of Revit. Please confirm this is a Revit 2019 software development issue or provide a solution. Refer to the attached sample files. Thanks!
2 ANTWORTEN 2
Nachricht 2 von 3
cbcarch
als Antwort auf: Anonymous
In Revit 2019, you can certainly control Visibility of linked elements ( such as walls) that are on a particular Workset from the Host model using Custom visibility setting for Linked models.
I'm not sure exactly what problem the user is having?
(I cannot download and test your Revit files due to company policy.)
Perhaps post some screen shots of the VG settings.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 3
The Filter seems to be incorrect.  Maybe that's why...
Yes that's why.  See second image attached.
