Revit View & Sheet (multiple) Renaming
BIMAbhi
Advisor Advisor
BIMAbhi
Is ther any possibilities to change the Revit View & Sheet Name and Number (multiple) without doing manually each of the sheet? We have created the sheet as per below mentioned naming:
Existing Sheet Name:
Arch-Cover Sheet
Arch-Floor Plan
Arch-Elevation
Arch-Section
Arch-Schedule etc.
Proposed Rename Sheet Name:
A-Cover Sheet
A-Floor Plan
A-Elevation
A-Section
A-Schedule etc.
Thanks in advance!
Thanks & Regards
BIMAbhi
constantin.stroescu
In such a case I'm using schedule:
  1. View >Schedules > Sheet List > make a schedule that contains among others Sheet Name
  2. In schedule , Sheet Name I type an A- before the name , then CTRL+ C -copy to clipboard
  3. Paste to the other names from the liast using CTRL+V
  4. The names will change in Project Browser...
Constantin Stroescu
