Hi all,
I've been using Revit 2019 and Revit 2022 depending on the company I do work for. If I download Revit 2023, will I still be able to use Revit 2019 and receive future updates? I know you can only go back 3 versions, just not sure what the consequences are if I download Revit 2023.
Thanks!
Gelöst! Gehe zur Lösung
Gelöst von alan.johnson7YLND. Gehe zur Lösung
You will still be able to use Revit 2019 but as far as I know 2019 no longer supported by Autodesk so it doesn't matter if you download 2023 or not.
2019 has disappeared from my Autodesk account list but I still have it installed.
