Revit V-Ray plugin
Revit V-Ray plugin
DrenAhmeti
Revit V-Ray plugin
DrenAhmeti
Hi all,
Just wanted to ask about the experience with V-Ray for Revit. Every time I enable it I have to go get a coffee or something it takes ages for it to open. Then, I can't save or anything because it just freezes, I have to disable it save it in cloud or whatever and then enable it again!
Has anyone had this problem and if yes is there a solution.
Thank you!
jvpantin2
It sounds more like a computer issue. Check out your PC specs and compare with V-Ray minimum requirements:
https://docs.chaos.com/display/VREVIT/System+Requirements
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
