I have a LAS file from a surveyor that I converted to an RCP file using Revit. When I insert the point cloud into Revit, the file is off a few feet Northing and Easting. If I insert the file using Civil 3D and set the insertion scale to U.S. Survey feet, the RCP comes in exactly where it should. Revit doesn't seem to be able to deal with this. Therefore, I wondering what scale I should use in Revit to correct the issue? Please help.
