Using revit 2018.0.0.420, can't access file generated in 2018.3, any suggestion for special procedure to make them compatible without upgrading revit application
similar issue with 2020.2.1 versus 2020.2.1.1
Any thoughts?
Thank you
Are you saying you can't open it period?
What's your reservation about applying the latest changes/fixes/enhancements?
As far as I know any 2018 file will open on any 2018 version.
same for 2020.
so if you are facing a problem opening a file, most probable it's not related to version.
Mostafa Elashmawy
