Revit, twinmotion and pointcloud
2 ANTWORTEN 2
Nachricht 1 von 3
nichlasAXHKY
413 Aufrufe, 2 Antworten
I have a point cloud that I used to build a new Revit model. Now, I want to transfer both the Revit model and the point cloud to Twinmotion. This is where I start having problems because I can't get the point cloud and the model properly aligned with each other. I can create a live link with Revit and import the point cloud afterwards, but then they are misaligned. I hope someone has a good workflow for this. :leicht_lächelndes_Gesicht:
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: nichlasAXHKY
Maybe this workflow?
Here's the gist:
Insert PC into brand new Revit Project (RVT) => Link the RVT containing the PC into Parent/Host Project => Establish Share Coordinates between the two.
Actually, better to select PC in the existing Parent/Host and Group it and then Link it -- and then establish Shared Coordinates.   This way will eliminate some manual repositioning work.
Nachricht 3 von 3
handjonathan
Hi @nichlasAXHKY
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
