Revit Tutoring
10 ANTWORTEN 10
Nachricht 1 von 11
1002 Aufrufe, 10 Antworten
Revit Tutoring
Hello All,
I'm interested in Revit tutoring/help. I would love for someone to be able to help me with:
1). Finding Revit components for their projects, and modifying Revit components in the family editor that were not able to be found.
2). How to make a Revit render look like a V-ray render.
I've seen many shared projects that have seem to have mastered both topics. These areas have been my biggest struggles with Revit. If you can help me, it would be greatly appreciated!
Thank you,
Whitley Bennett
10 ANTWORTEN 10
Nachricht 2 von 11
Sahay_R
als Antwort auf: Anonymous
Post a specific problem, with supporting screenshots / families / projects. Someone should be able to come up with a solution.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 11
biztrobill
Hi. I'm new to Revit also, so I can relate to your situation. There are hundreds of Revit videos on YouTube, and maybe a few are actually helpful. So far I've learned the most from lynda.com. It's a paid subscription, but the tutorials are far and away the best I've seen.
Good luck!
Bill
Bill Fowler NCARB
Revit LT Suite 2024
Mac M2 Pro Mini, Apple Studio Display; w/ macOS Ventura, Parallels 18, Windows 11. 32GB memory (Parallels assigns 16GB for Windows virtual machine)
Solo Architecture practice in residential and small commercial design.
Tags (1)
Nachricht 4 von 11
Viveka_CD
Hi @Anonymous
Good to know that you are interested in learning Revit. Smiley (fröhlich)
Access resources as listed on our knowledge network page, that can help you learn how to use the software. Click HERE
2) Please check out videos related to Revit, available for download at the Autodesk design academy website
We have Starter Files, Software Tutorials, Instructor Manual and Design Thinking Videos available if you click on the asset download link for each video.
3) You can search classes available and you can download them from our Autodesk university website
4) See a guide to Autodesk Revit Architecture
5) Check the tutorials HERE for V-Ray for Revit
Tags (1)
Nachricht 5 von 11
JJWGallagher
You could get V-Ray for Revit, but it won't look as good as if you did it in 3ds Max or another 3d application. There is no magic button for renders. It takes a lot of time, practice, and patience.
Nachricht 6 von 11
als Antwort auf: biztrobill
Bill,
Thank you for your suggestions!
Whitley
Nachricht 7 von 11
als Antwort auf: Sahay_R
Rina,
I will thank you!
Nachricht 8 von 11
als Antwort auf: JJWGallagher
Understood, thank you!
Nachricht 9 von 11
als Antwort auf: Viveka_CD
Thank you for all of your suggestion!
To be a little more specific, finding components have been a challenge. There's sources like Hermon Miller that has Revit files, but not all manufactures have Revit files. Which then results in you having to make your own, or modifying something similar to it. Knowing where to look is key and knowing how to modify what you want is key as well. Having someone who has wisdom in this area would really help me in developing a solid workflow.
For Example:
  1. These are great website/vendors that mostly have Revit files.
  • Hermon Miller
  • SteelCase
2. If you cant find the files this is my workflow
Model the components in sketch.
  • The best thing to focus on is...
    • Furniture and materials
Focus on the structure and architectural features in Revit
  • the main thing I do in Revit is this..
Render in V-Ray and or the Cloud
  • The key settings are..
I use Photoshop when I cant find components
  • The key things to do is...
    • People
    • Lighting
    • shadows and highlights
Or someone just has a workflow in Revit as far as editing materials and modifying components without the use of the other software's.
If someone can share their wisdom and their journey in developing their workflow that would be extremely insightful.
Thank you,
Whitley
Nachricht 10 von 11
JJWGallagher
It looks like you're trying to use Revit as a 3d modeling and rendering program, is that all you're after? If so you have have more luck with another program, that is made for that like 3ds Max, Maya, or even SketchUp. If you're looking for an easier solution at the cost of visual fidelity (and your bank account) you may want to try something like Lumion or TwinMotion.
Nachricht 11 von 11
Yes the 3D Modeling and Renderings is what I'm after, I will give the other software you mentioned a try!
Thank you!
