the highlighted area is missing from the schedule and the tutorial failed to indicate this as the tutorial does not contain the same data as the downloaded file.
Gelöst! Gehe zur Lösung
Gelöst von mercylovegrace688. Gehe zur Lösung
I found the view already have the room but only after using the schedule properties.
The rooms are there evidently by the room tags. Check the color scheme see if boxes unchecked or set to no color.
