Is it possible to turn off the brown topo patter below the ground when the section box cuts the model?
John Mayo
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Edit: Seeing that tunnel in the image, building pad might not be ideal for that spot...and you might need something similar to what is discussed on the following Post
https://forums.autodesk.com/t5/revit-architecture-forum/earth-filling-the-plan/m-p/9260427
Thanks for the tip but I don't believe a building pad will expose the piles or the culvert opening. I did try this with the basement but that didn't help either even with a transparent material the cut topo shows. I really need to turn of the brown topo cut patterns to see what I need to present.
John Mayo
Need some time to look at the other solutions. Will reply back soon.
Thanks again.
John Mayo
Bingo!
#2 hit the nail on the head. Changed the poch material.
Thx a bunch
John Mayo
