Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Revit to Lumion - Huge File Size
A.Sobhy
A.Sobhy
Hi
when i export my revit model (600mbs) to Lumion
the exported DAE file comes in a huge size (4 GBs), even when i tried to export to DXF also it comes huge (2.5 GBs)
since two days ago, i am looking for solution, but i didn't find any thing helps.
please advise urgently
Thank You
cbcarch
It sounds like you need to do some model management in Revit--a 600 MB file is fairly large.
More important however is how many polygons / triangulated surfaces the model contains, which is most likely what is driving up the file size in the Collada export.
Try breaking up the model into Worksets--turn off un-needed elements that you don't need in the Lumion scene.
Purge the Revit model.
Delete any Raster Images
Delete any Cad Links or Imports
Take a look at Families which are loaded into the model. Check for any alrge file sizes ( .rfa)
If families are large/complex/have Cad imports contained in them, this will bloat the Revit file and subsequent exported Collada file.
Try using a Section Box to cull/crop the view that you export for Lumion.
Are you using the Lumion plug-in to export? There may be settings there as well- not sure about that.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Viveka_CD
Autodesk Support
Autodesk Support
Hi @A.Sobhy
You can minimize the size of your Revit® files in order to optimize project performance.
Remove unwanted cad/rvt links and unused raster images in your model.
See article HERE for solutions
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome.
Viveka_CD
Autodesk Support
Autodesk Support
Hi @A.Sobhy
I just wanted to follow up here, any progress on this issue?
Please mark any posts that help with "Accept as Solution" and thanks! Kudos welcome.
