Revit to Inventor workflow
For a manufacturer of building products, it's highly desirable to be able to receive all (or part) of a Revit model and be able to use it inside Inventor as a reference model or underlay.
Currently the only option is to import it either directly as a SAT file, or by opening the RVT file in Inventor - which is actually doing a SAT conversion in the background anyway. Importing data is a really bad workflow because it's a "one-time" function. If the Revit file changes, you have to re-import the model - effectively trashing most of the hard work already completed in Inventor.
Yesterday it struck me that if Revit could directly export a STEP file, then Inventor's AnyCAD technology can already handle dynamically updating everything built around that STEP file as an underlay. If the Revit model changed, a new STEP file could be exported, and Inventor would update everything based on the new geometry. (Perhaps the better "idea" for the Inventor Idea Station is that they extend the AnyCAD supported formats to include some more of Autodesk's own file formats!)
I realise there is a STEP translator available in the Revit APP store, but my "idea" is that it should be added to Revit as a "standard" feature.
