I've been having trouble figuring out why my Twinmotion file size increases drastically after loading a .fbx file (export from Revit)?
I even made sure to delete any other background or previous links that I would be replacing with new files to assure that I'm not duplicating any links unnecessarily.
Here were the steps I took:
Any ideas why Twinmotion would exponentially increase the file size when the total size should have been only about 230MB (48+184)?
Gelöst! Gehe zur Lösung
When I worked with Twinmotion and Revit, I used "Twinmotion Dynamic Link" and it works smoothly!
https://apps.autodesk.com/RVT/en/Detail/Index?id=5061930675590642657&appLang=en&os=Win64
Do not need to export and import method, just one click!
I have tried this FBX but the ending result is weird. No lights, no materials.
