Revit to fbx export lose materials in f.e. Unity/Unreal Engine
4 ANTWORTEN 4
Nachricht 1 von 5
lukasz.banaszkiewicz
2890 Aufrufe, 4 Antworten
I have an issue with Fbx export from Revit. I have a Revit file (well prepared, with materials etc.). When I open it in 3ds Max and save it as fbx, after opening, eg in Unity, all materials are preserved.
When I open the same file in Revit and export to fbx I get situation in any graphics engine (Unity, Unreal Engine), the project loses materials, and in principle has one, called 'No NAME' and the same for each object. In addition, if Revit object has several materials in Revit, only one is shown after fbx export, also 'NO NAME'.
Have you met this situation before, you can advise me something ... any direct way to do this without losing mats?
4 ANTWORTEN 4
Nachricht 2 von 5
L.Maas
als Antwort auf: lukasz.banaszkiewicz
Yes, this is correct. The materials used are not recognized. You can solve this as follows:
-Export your files as fbx from Revit.
-Open the file in 3dsMax.
-Go to Scene Converter (in Rendering menu).
-In the Editor tab convert all source materials to destination standard materials.
-Export the file to fbx.
-Import in Unity (not sure about Unreal)
All your Revit materials should be there.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 5
als Antwort auf: L.Maas
I know it's possible to do this by using 3ds Max but...
- we want to do this without using any other software (Revit has fbx export - how come it doesn't work in right way?)
- if you have to do this for few models it's quite OK but if you have hundreds of them it's not good solution
Nachricht 4 von 5
DarrenP
it does work the fbx export is designed to work with 3ds max
you will have to go through 3ds max then to unity or unreal
DarrenP
Nachricht 5 von 5
The ideal work around is to download and install the datasmith exporter from Revit on their website and use the .udatasmith file type.
Installing the Datasmith Exporter Plugin for Revit | Unreal Engine 4.27 Documentation
