REVIT to DWG
REVIT to DWG
00353629
REVIT to DWG
00353629
Hello, when i export the revit file to dwg. the doors and windows family cut the lines of the wall (example in the image) is there a way to avoid this problem? I don´t if it is from the family or just a revit system that i can´t change. Thank you
00353629_0-1719002595755.png With windows and doors as block in AutoCAD
00353629_1-1719002637298.pngWhen i turn the windows and door layer off
TripleM-Dev.net
Hi @00353629,
Revit dwg export doesn't include "hidden" geometry like something on a "AutoCAD DontPlot layer", if a part of a element isn't visible in the view that part isn't exported. This also includes elements that are over each other.
I don't know the mechanism revit uses for determining which part of overlapping lines of 3D objects are determined, by linewidth or order of element creation (door will always be placed after the wall so is higher in order?)
So either the line of the wall is left out or from the door.
If you only need the walllines (or something like that), make a dwg with the other elements invisible.
We don't have that issue.  Can you provide more information about your workflow?  Maybe post the RVT?
