Hi everyone,
I’m facing an issue with DWG export from Revit and I’m trying to understand what might be causing it.
I have configured a custom layer naming setup where a prefix “ARC_RVT_” is applied to all exported CAD layers. In most cases (around 80%), this works correctly — the layers are exported with the expected prefix.
However, there are several layers that do not include the prefix at all, even though they appear in the same exported file. You can see this behavior in the attached screenshot — most layers follow the naming convention, but a few (e.g., A-FLOR, A-GENM, etc.) do not.
What I’ve already checked/tested:
Prefix is correctly defined in Export Settings (both for Projection and Cut)
Export performed with:
All Revit links unloaded
All imported CAD files removed/disabled
In AutoCAD:
Tried Quick Select on elements from incorrectly named layers → no elements found on those layers
This makes it even more confusing, because those layers exist in the DWG, but don’t seem to contain selectable geometry.
Questions:
Has anyone experienced a similar issue?
What could cause certain layers to bypass the defined prefix?
Could these layers be generated internally by Revit (e.g., system layers, empty layers, or export artifacts)?
Is there a reliable way to prevent or clean this behavior?
Any insights or workarounds would be greatly appreciated.
Thanks in advance.
