is it possible to export revit file to cad with colors that are seen in realistic view?
Gelöst! Gehe zur Lösung
Gelöst von Karol_Piroska. Gehe zur Lösung
I'm not sure if any of this is possible in Revit 2022 but I know in earlier versions we're not able to
AutoCAD used to have FBX import and it was removed in AutoCAD 2019. Your current option is to export Revit model as NWC/NWD using extension plugin. Click on the link
https://www.autodesk.ca/en/products/navisworks/3d-viewers
Then in AutoCAD, you attached it as Coordination model.
This will preserve the material.
