Revit to AutoCAD LT
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
2344 Aufrufe, 2 Antworten
Revit to AutoCAD LT
Can a Revit file be opened/manipulated in AutoCAD LT? If so, how?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
No.  A Revit file must be exported to DWGs to open in AutoCAD.
An AutoCAD file, on the other hand, can be linked or imported into Revit directly.
Nachricht 3 von 3
Viveka_CD
Hi @Anonymous
I see that you are visiting as a new member. Welcome to the Autodesk Community! Smiley (fröhlich)
I agree with @ToanDN, see HERE for exporting views and sheets to DWG or DXF format from Revit.
Before exporting a Revit model, consider these best practices:
  • Reduce the amount of model geometry to be exported. See About Limiting Model Geometry Before Exporting.
  • Create or modify layer mapping to ensure that all the information stored in Revit categories and subcategories will be exported to the proper CAD layers (or levels, if exporting to DGN). See About Layer Mapping for Export.
  • Adjust the view scale to control the precision/performance ratio.
    When you export to 2D DWG or DXF, you export a scaled 2D view of the model. The view scale you apply determines whether the resulting view is exported for precision or for performance. For example, if your model contains 2 lines that are 1/4" apart and the view scale is 100, the lines will be considered to be within tolerance, and the exported DWG will contain a single line (exported for performance). If the view scale is 20, the exported DWG will contain separate lines (exported for precision).
Let us know if you have additional questions.If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you.
