HELLO,
I am trying to create a new title block, however when I click as follow FILE- NEW - TITLE BLOCK ( THE FOLDER IS EMPTY) What should I do in this case?
Copy these file to tat folder. But for the long run, you need to re-install library content for Revit.
i don't see a directory path, where specifically are you pointing to?
should be C:\ProgramData\Autodesk\RVT 2020\Family Templates\English\Titleblocks.
Howard Munsell
Download Library of autodesk family
@shahaznie wrote:
ACCEPT SOLUTION
Are you saying @ToanDN response was the solution?
Howard Munsell
