In this topic, I will be addressing some amazing functionalities that can be done with the Revit families.
Changing the hosts of Revit families without having to re-create them, and keeping all the parameters working perfectly,
It's like adding super powers to a family!
Now, here's the thing.
When it comes to situations where you need to convert a family from (Wall, Ceiling, Roof) -based into something like Face -based family,
You either re-create that family, OR
You use the Copy/Monitor trick (a bit tedious) and may cause some problems as the following family broke due it’s high complexity and relations with the host:Now, I had this situation with a pretty complex family I created as a Wall based, then I decided to make it a Face based and a Ceiling based family.
Here’s a snapshot from its parameters:Of course, it would take me a long time to recreate that family,
And copy/monitoring didn’t work out as it broke, as shown in the beginning
So, I had to move to another SOLUTION:Here comes the KCONVERT Family: A family I have created that can capture anything, and change it into anything
Examples below show what I mean.
-A Lighting Fixture Family Ceiling-based converted into an Adaptive that contains a Face-based exact lighting fixture Family, while keeping all of its parameters functioning perfectly!
-A complex Lighting Family (Wall based) family converted into a Face based, and a Ceiling based, with multiple directions, and additions, while keeping all the parameters without the need of re-creation!
-Window family that didn’t act correctly to curved surfaces or slanted ones,
Got fixed up and is now working correctly!
Here is the link to my YouTube video where I explain it all with two examples (28 Minutes) : http://bit.ly/2j2DnNI
The KCONVERT Family download (Saved in Revit 2014) : goo.gl/46TMuT *
SUMMARY
Additional Notes:
ABOUT KARAM BAKI
Karam Baki is an Architect currently studying in the University of Jordan. He started his Revit journey in 2009 at age 16, and recently when he turned 21, he was inducted as an Autodesk Expert Elite member. He's one of the Top StudentExperts at the StudentExpert Network.
Karam is also considered as a leading expert in Jordan for Revit, an instructor at the University of Jordan while still learning as a student at the same time. Karam has created many projects for various clients as well.
Check out Karam's students' work at this Facebook page: https://www.facebook.com/revitelites
Check his own work on the Autodesk Gallery page: https://gallery.autodesk.com/users/BPT3NVQXP4A2
Basically an extension to import to a face-based family?
What did you do to the 'placement' families so they don't have a category associated with them?
I like to see the video how you covert them.
I also am looking for the possibilities.
With the copy monitor trick i do not have to connect the parameters 2 times.. but i can convert a wall based template to a face hosted template.
With my work i do not wont to connect the parameters each time.
Connecting the dots two times to me is a disadvantage...
I hope you have a tip for this one.
The only problem with face host based templates and other non hosted templates is that the scheduled level has to been set manually.
Only the face host based placed with the option on vertical plane in a plan view sets it automaticly right..
Hey Ramon,
Thank you ![]()
Let's breakdown those one by one :
-Copy Monitor trick is not stable for complex families, I have added an example above, Also you may check this conversation about it,
https://www.linkedin.com/pulse/revit-wall-host-family-face-based-trick-sandip-more
It destroys the groups and the parameters will not function probably, if it was complex enough, as almost all the professional families are,
That trick works for only "One time usage" I mean you will loose all the parametric abilities, and that's something we agree to not like,
So, the very stable trick is the KConvert above, I agree it might be a little bit time consuming, but not more than 5 minutes per family,
Which is much less than copy paste it's elements are reconnecting references and parameters, especially with fairly complex families,
Also all the parameters are kept safe and fully functional unlike the copy/monitor trick
However, for the connecting the dots, Ron Allen advised me to create a piece of API, or with the help of Dynamo, to achieve that automatically, wish me luck with it
, but for now, if you want a stable, face based converted family, the above method serves you well,
Regarding for scheduling, this is how Revit is designed, no way to change it,
Here is a breakdown to it
-While in 2D, it automatically sets the schedule level to the associated level of the view you are in, no need to worry about it,
-While in 3D, just make sure you get the right level, from the option bar, it will set it self automatically in the schedule level
You may tell me that I have to get it right when using it in 3D,
As for wall based templates, they capture the level automatically, (BUT NOT ALWAYS), that happens with my daily workflow, especially if am messing a lot with the workplane am drawing at, for Model Text and dimensions in 3D,
This is a trade I accept, will keep up looking for better solutions, but it is as it is now, it is not between my hands,
Hope I understood your comment right ![]()
@AnonymousFace based families automatically report their placement level- but can be overridden.
@Karambaki If groups failed - what about assemblies? Do assemblies fail on copy/monitor? May be a bug in revit if that is the case. Have you tried C/M in R2017?
@GallowayUS_com_RonAllen1 Assemblies as expected, and no need to worry about them because we are talking about the families, and assemblies are not used in the family environment as you know,
The failure is inside the resulted family if it contained groups and used the C/M method on it,
Revit would give you this if your family contained Array group based on the wall for example, :
An error occurred in family "ANYFAMILY.rfa" and was automatically resolved. Please review changes made to the family.
Error Information:
"Changes to groups are only allowed during Edit Group mode. Use Edit Group to make this change."
Error Resolution: Delete Element(s)
And the result has a broken groups in family, broken parameters, broken life ...
Using the KConvert method, will preserve that and not break any thing,
@Anonymous, thanks for the response
@Anonymous, thats right but that is also what I mentioned about face host based .. only in plan view this works not in 3d.
@ron.allen
@ramon697348385
It's been a long time,
You asked before about the schedule level of the face based hosted families, that it sometimes doesn't report the level you want if you used them in 3D views,
I have created a Dynamo Script that solved this problem, it also solves many other problems regarding that issue,
It can work with 2 scenarios :
1- If you have face based hosted families, it will automatically detect what is their appropriate level to host on
2- If you have wall based family (or any non-hosted family) that has it's offset and level parameter reporting from a far level,
The script can detect the level and the appropriate offset and fixes it, along with the (optional) possibility to modify the rounding of the offset, so it reports clean values in schedules and keep up the model's quality control
@fabiosato my friend from Brasil he's a MEP specialist, tested this script with mechanical pipes and families to justify and fix their levels and offsets so they appear appropriate in the schedule, a task that takes lots of time, automated in couple of clicks
You can have it from Synthesize Toolkit package extra folder from Dynamo
Screenshots :
BEFORE : Levels and Offset of windows are incorrect, although I made a normal array,
BEFORE : Schedule Levels are incorrect
AFTER : Levels and Offset are set to their correct values
AFTER : Schedule Levels are all set to their correct values
This is just a simple example, the run time is less than a second in this example, we tested it in a huge project, the run time is really really short, with more than 1000 families that needed to be corrected, it took 1 minute to finish up and keeping everything in location while having their offsets and levels corrected ![]()
Script name :
Family.Refine Level and Offset
Enjoy ![]()
