Dear Autodesk,
We are a small architecture practice and working with Macs throughout. We are running Revit through Bootcamp and have only recently started working in this way. There is a problem we have encountered when a colleague is trying to create a local file. Through online research it seems that Windows and Mac path folders differently and this is possibly the issue to correct.
I hope the above detail is clear enough to gather a solution.
Thank you in advance.
Hello, Paul.
Regarding your multiple questions in the forum, I would like to take on as many as I can answer for you.
First, Revit Worksharing: I did research, and only found other forums addressing this Worksharing issue from many angles. The most complete information I found about this is available >HERE<, where multiple users have discussed workarounds to get it to work, with servers and added hardware. This forum also addresses Bootcamp Revit.
Points three, four and five are related to AutoCAD, and cannot be serviced here, as this is a Revit Forum. Any AutoCAD questions need to be redirected to their own specialists.
