I received a DWG file that was part of Revit, however the file is very large 25KB is there a command in autocad that I can make it smaller. I have tried purge and overkill.
Gelöst! Gehe zur Lösung
Gelöst von chris-reese. Gehe zur Lösung
Gelöst von RobDraw. Gehe zur Lösung
25K is not very large. Was that a typo?
Check if there are any XREFs attached to it as well. LAYDEL might help remove some unnecessary layers too.
