I am running Revit 2017 STUDENT VERSION in a Windows 10 64bit with a NVIDIA GeForce GTX 960M. While setting the realistic view on floor plan I cannot see textures. Nevertheless, if I set the 3D view I do see textures.
Do somebody know if it is an issue of my hardward, my drivers or the way I have Revit configured? Everything else works just fine.
Gabriela
Gelöst! Gehe zur Lösung
Gelöst von samuelsanf. Gehe zur Lösung
Is Detail Level set to fine on that view?
You try to disable hardware acceleration and restart Revit?
J. Samuel Santana F.
¿Te resultó útil esta publicación? Dale a Me gusta.
¿Tú pregunta fue respondida correctamente? Haz click en el botón ACEPTAR SOLUCIÓN.
Does it still show the same material color or a different one? What sort of texture you use for the floor?
