Revit Texture & IFC
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
2684 Aufrufe, 4 Antworten
Revit Texture & IFC
I have a problem with my IFC file. In Revit, i created a building, my own walls and materials. Also i imported png files in this metarials, but when i try to export IFC, can't see textures. In Revit, it is possible to see texture, but in IFC have a problem. Can you help me about this problem?
Tnaks,
Tolga.
4 ANTWORTEN 4
Nachricht 2 von 5
Karol_Piroska
als Antwort auf: Anonymous
IFC does not support textures. In fact showing real textures/materials (mainly anything custom) outside Revit is not really possible, not even within Autodesk's own online services..
Nachricht 3 von 5
als Antwort auf: Karol_Piroska
Thank you but i have one more question. In some forums says export with texture is possible with IFC 4. Is it possible?
Nachricht 4 von 5
L.Maas
With IFC4 this should be possible. Not sure how far the integration. You can follow the IFC add-in on Github.
As we use it for conversion to other parties we are normally limited to IFC2x3. IFC4 is not supported everywhere.
What is the purpose of your IFC file? Maybe a different file format would suit your needs better
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 5 von 5
als Antwort auf: L.Maas
I am trying to create a CityGml file from IFC, in revit i created all textured buildings and i want to transfer this information to my gml file. Otherwise i need to re-texture all buildings.
Thank you so much
