Revit- text Field
6 ANTWORTEN 6
Nachricht 1 von 7
zsolt
273 Aufrufe, 6 Antworten
Revit- text Field
Hi
How can i add a Textfield (in autocad is very simple) with "component type-door description".
6 ANTWORTEN 6
Nachricht 2 von 7
theslacollier
als Antwort auf: zsolt
Is this a shared parameter? B/c it is you can use tags and path the label to that parameter if it is a project parameter it won't be able to be tagged
RVT to the max
Nachricht 3 von 7
Create a door tag and add the Description Field to the label.
Nachricht 4 von 7
zsolt
als Antwort auf: theslacollier
 where can i find the paramter text field ?
Nachricht 5 von 7
pessi.symb
you mean the description of the door? if the values are properly inputted in the Type / Instance Parameter of the Dolor, this can be automatically done  in Dynamo. So when the values change, this door schedule also changes...
Nachricht 6 von 7
zsolt
als Antwort auf: pessi.symb
Exactly. How can i put the description of the door in  text, with a simple click on the door, takes it the properties , and change automatically the description (ex. Interior-Double -Full glass... ) without using copy/paste or type one by one.     Dynamo :nachdenkliches_Gesicht:
Nachricht 7 von 7
pessi.symb
