When we create a new project, when can select "<None>" and Revit asks if we want Metric or Imperial units. Where are these default templates ?
I checked all the files there "C:\ProgramData\Autodesk\RVT 2022\Templates\" but no one is the same than the one used when "<None>" is selected.
in this address you can find Default_M_(ENG,ENU,CSY,etc) or in
C:\ProgramData\Autodesk\RVT 2022\Templates\English-Imperial
you need to install content library first?
@azad.Nanvathanks but I tested all these templates and no one is exactly the same than the ">None>" one. The views and the families are never exaclty the same.
@ennujozlagameverything is installed, but I re-installed them just in case. Thanks for the advice
@RSomppi In my company we are doing test to insert IFC and use its geometry as room-boundary. Depending of the template the result is different but it seems perfect using the "<None>" template, so we asked ourselves where is this template located ?
That being said, it's still possible to create a file from this template and saveAs template. It's just a curious question if this file exist somewhere or if this file is generated by some code.
Okay, as long as you know that you can create a copy without really knowing where that file is, if it exists. I would assume it exists and may be hidden from users intentionally.
@lvirone wrote:@azad.Nanvathanks but I tested all these templates and no one is exactly the same than the ">None>" one. The views and the families are never exaclty the same.
you can ask from Autodesk,but i think if you choose None, Revit use Defualt Template and delete all views except Level 1 for Active View
if you need this template you can Save as the project as Template and change it to your desire
Choosing “None” means Revit is creating a file with the minimum elements it requires to function, probably internal code driven.
Steve Stafford
