Greetings!
I'm trying to annotate the reinforcements. Shown on this example there are 4 rebars in the column but Revit shows 1 as the quantity. How can i show there 4? In the second photo you can see what i want but i did it not with tag tool, but with text tool.
Thanks for help in advance and have a nice day!
Are they part of a REBAR SET or did you place individually (one at a time)?
Well then, there you have it. Revit doesn't know that. If you want Revit to tag as a 'UNIT", then put the 4 into a REBAR SET. Otherwise, tag individually.
If i put 4, then i have 4 rebars in one single direction. But i need 1 rebar for each corner at the column.
